Compile AVR to BIN
Posted: Tue Dec 06, 2016 1:37 pm
by jimha
How can I compile my AVR (Xmega32A4) to BIN format?
Thanks!
Re: Compile AVR to BIN
Posted: Tue Dec 06, 2016 5:25 pm
You can try replacing the file in the "Flowcode 7\compilers\avr\batchfiles" folder with the attached file. This should generate an additional .bin file for you when you compile.
avrb.bat
(666 Bytes) Downloaded 269 times
Please note the file produced will be a ProjectName.cof.bin mainly because I have hacked it in there. If the .cof causes any problems then it might need to be manually removed from the file name.
Posted: Mon Dec 19, 2016 5:05 am
by jimha
It works w/ Thanks!
Posted: Fri Jul 05, 2019 10:19 pm
by MarekRS2
Hello, can I compile .bin file for PIC 8bit MCU?
