Advise correct method for own component
Posted: Wed Dec 07, 2016 8:53 am
by QMESAR
Hi All.
I need help advise on what would be the steps or correct method in FC ,
I have a project that I would like to run purely in FC as the project would require that I use a lot of my own functions foe example to configure and drive the Motor Control PWM module on a dsPIC33 to name one
now I know I can use a C call to do that but I was thinking is it not possible to embed this C function call into a component Icon that would give me for example PWM_MC Initailze and calcualte set point and so on then I would have icons on the Flow chart or is it better to make a complete component ?
I guess I am not sure what to do embed the C code into an Icon or make complete components and then in both cases I have actually no clue where to start :D any input advise or direction is highly appreciated this is quite important for me as since FC7 I am trying to fully move over to FC and not run both C style projects and FC However I need to make the FC charts lean and not having 100 C call icons in a Flowchart
The simulation part of FC is interesting but that is something I rarly use I code run and debug on the target hardware in my opinion (with my little knowledge on FC ) I would like not to add all the simulation features to my Component or icon that embed my C code
Thanks a million for your support
Re: Advise correct method for own component
Posted: Wed Dec 07, 2016 10:04 am
by LeighM
To create a component that has some custom API...
Just create a new project and your required macros, that contain Flowcode icons and C icon code.
Then use the Interface manager to change your macros into "Downloadable"
Then create your new component by File->Export component
Give the new component a name and a new GUI ID (just the first time you export it)
Refresh or rerun Flowcode, then use search to find and use your new component.
There is an example here...
http://www.flowcode.co.uk/mmforums/viewt ... 386#p73065
Hope that gets you started.
Leigh
Posted: Wed Dec 07, 2016 12:35 pm
by QMESAR
Hi LeighM
Thank you this helps already a great deal just tried it and I could export one of my makro's
I will slowly start to use these techniques to improve myself and my FC knowledge
Many Thanks
Posted: Wed Dec 07, 2016 12:42 pm
Posted: Thu Dec 08, 2016 12:12 pm
by Steve
So you are aware, we have been working on component creation and the next 7.2 release of Flowcode will have a number of features to make it much easier. We'll have more information available in the new year.
Posted: Thu Dec 08, 2016 12:43 pm
by QMESAR
That sounds really good looking forward to this :D
Posted: Thu Dec 08, 2016 12:44 pm
by QMESAR
Sorry double post
