DTH11 sensor with relay
Artis
Has thanked: 1 time
Post by Artis »
Hi can someone know how to connect relay to DTH11 sensor temperature readings. I added my flowcode file, in it in decison "relay ieslegsanas" i want to input "str>28" but its give me error. i think is becauce i should change str to bite. But when i do that my sensor readings aren't fine.
DHT11_Strada.fcfx
(11.13 KiB) Downloaded 262 times
Re: DTH11 sensor with relay
This should hopefully help. I use the strings to send data to the LCD and then read the temperature value again but this time as a whole number rather than a string. This way I can make the comparison directly on the value.
DHT11_Strada.fcfx
(11.52 KiB) Downloaded 267 times
You could add some hysteresis to stop the relay from oscillating on and off like this.
Artis
Has thanked: 1 time
Post by Artis »
Thanks it's help a lot.
