HC05/HC06 macro has strange response?
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I've made the attached flowchart to send and receive data with the HC05 HC06 Bluetooth module.
It should respond to a certain number I send via a Bluetooth terminal.
In Arduino it works fine but in Flowcode I get this strange response.
It should dim a green led when it receives "1", and turn the green led on when receiving "2".
It should dim a orange led when it receives "3", and turn the green led on when receiving "4".
This is how it works in Arduino.
When I make the same program in Flowcode, the numbers it responds to aren't 1 to 4, but 98/100/102/104
These are double of the ASCII characters (I just found out when typing..)
Why are these values doubled??
Anyone an idea??
Bluetooth1.fcfx
Why is the "back" value doubled??
(10.06 KiB) Downloaded 317 times
Has thanked: 481 times
Been thanked: 699 times
Re: HC05/HC06 macro has strange response?
It looks like a software UART timing issue, please could you try the attached updated CAL file?
It needs to go into your Flowcode7 installation "CAL\AVR" folder/directory.
Probably a good idea to make a backup of the one it will replace.
Thanks,
Leigh
AVR_CAL_UART.c
(57.04 KiB) Downloaded 299 times
MJU
Post by MJU »
LeighM wrote:Hi,
Thanks,
Leigh
This is it!
Now it works like it should!
Was that a flaw in the UART Leigh?
Thanks for your help!
