Missing component in system/dashboard panels
Posted: Wed Feb 22, 2017 1:47 pm
by Jan Lichtenbelt
I do use the system or dashboard panel only to set the properties of the components which I use in the Flowcode. But sometime I add a new component and then after a while I'm missing the component and do not see it anymore. The component is clear not the visual windows but somewhere else, form - infinit to + infinit. How do I get the component in the visual window back?
With kind regards
Jan Lichtenbelt
Re: Missing component in system/dashboard panels
Posted: Wed Feb 22, 2017 3:57 pm
Hi Jan,
You can use the drop down menu at the top of the properties window to see the components present in your program.
- PropMenu.jpg (63 KiB) Viewed 2724 times
You can then select the component you have lost from the list, go into the Position tab of the properties window and change the coordinates back to 0,0,0 to re-position the component in the middle of the panel.
- PropCoords.jpg (12.25 KiB) Viewed 2724 times
Both panels have a right click menu item to "Look at the origin" and "Zoom to 100%" which should help navigating to look at 0,0,0.
- PanelMenu.jpg (9.82 KiB) Viewed 2724 times
