1 sec delay is 4 sec
Posted: Thu Mar 02, 2017 1:36 pm
by go233
very strange: I wrote a very very simple code to have a 4 relays turning on and off every second and the delay is 4 sec instead between two clicks?
do you know why?
flowcode 6 v 6.1.2.0
EB-006-00-9
EB-038-00
micro PIC18F2455
Giovanni
Re: 1 sec delay is 4 sec
Posted: Thu Mar 02, 2017 1:45 pm
Hello Giovanni,
We use delays to confirm if everything is setup correctly.
http://www.flowcode.co.uk/wiki/index.php ... ED_flasher
It sounds like something may be off in your software. Looking now...
Posted: Thu Mar 02, 2017 1:47 pm
Problem is your configuration settings.
You have the CPU Sys CLK Select option set to OSC/4, I suggest changing this to OSC/1 and things should then work as expected.
Posted: Sun Mar 05, 2017 11:00 am
by go233
oh! silly mistake!
Giovanni
