hello,
Is there any way to use switch led,with no connection pin, for siMulation only?
I use led turn on and turn off without connection pin and it's not run....
switch led etc.. for siMulation only
Re: switch led etc.. for siMulation only
In the component search type in LED, in the list of results you should find the item "Simulation LED" which is essentially an LED without a pin connection.
A lot of the v6 components were hidden to ease in new customers and to only show components that most people would understand and use, we didn't want to overwhelm new users with lots and lots of unfinished or unpolished components.
For v7 we have ordered, polished and exposed components much better so now almost everything is part of the main component lists.
