Help with interruption
Posted: Tue May 09, 2017 6:36 am
by RLOPES780
Hello friends;
I'm using pic 18f2423 and need to generate a 1hz interrupt to call a macro.
Looking at the properties of timer interrupts 0,1,2,3 I can not create a interruption of 1 hz.
I have the code attached, someone could help me how can I configure this interruption
Grateful;
Ricardo.
Re: Help with interruption
Posted: Tue May 09, 2017 9:04 am
Hi Ricardo,
Attached Flowchart (Untested) should clear MAXIMO every second.
I have set interrupt for 200Hz.
Therefore if interrupt macro is accessed 200 times then one second has elapsed.
Posted: Tue May 09, 2017 1:09 pm
by RLOPES780
Hello Martin;
Thank you for your attention and willingness to help.
Looks like it worked !!!!!
What I really need is to reset the maximum variable every 1 second.
And that's what you did?
I just do not understand The clock is 32 MHz and the interrupt frequency is 200 Hz. How does the interruption occur every 1 second? Can you explain me?
Grateful;
Ricardo
Posted: Tue May 09, 2017 2:10 pm
Hi Ricardo,
Glad It works.
RLOPES780 wrote:I just do not understand The clock is 32 MHz and the interrupt frequency is 200 Hz. How does the interruption occur every 1 second? Can you explain me?
As stated on the above post
medelec35 wrote:I have set interrupt for 200Hz.
The interrupt is not triggered every second as that is not possible at 32MHz
So the interrupt is triggered 200 times every second.
If a count variable called INTCount for example is incremented every time interrupt is accessed, then when
INTCount = 200
then 1 second has elapsed.
You can use a decision branch
If:INTCount = 200
 INTCount = 0
MAXIMO = 0
RLOPES780 wrote:What I really need is to reset the maximum variable every 1 second.
Every second
MAXIMO = 0
So if that's the intention then yes.
