Opimization Level of GNU ARM Compiler
Posted: Wed May 31, 2017 10:48 am
by eSYS.co
How can I change the optimizer level of the GNU ARM compiler?
And at which stage the Compiler is located in the Flowcode standard ?
Thank you for Help !
Andreas
Re: Opimization Level of GNU ARM Compiler
Posted: Wed May 31, 2017 11:01 am
by LeighM
The settings are in stm32comp.bat located in your Flowcode7 installation sub-directory \compilers\STARM\batch
You could create your own version of this and change the settings in Build->Compiler options to run yours instead of the default.
Let us know if you find any interesting optimisations :D
