Injector tools
A forums to allow resolved bugs and problems with Flowcode v7 to be stored and marked as resolved.
sundgau
Has thanked: 5 times
Been thanked: 10 times
Injector tools
Post by sundgau »
My computer does not have a physical port; So I created a virtual port that I can see on Fc6 but not on Fc 7. Why?
Can you explain me to avec com port on fc7?
Thank you in advance
Bruno
(43.18 KiB) Downloaded 3041 times
(46.93 KiB) Downloaded 3041 times
Re: Injector tools
As far as I know v6 and v7 use the same DLL library to access the COM ports, so in theory they should be exactly the same.
Do you have the COM port open in another piece of software?
Have you tried using the refresh property, set to Yes and this should refresh the Port list for you.
One other thing is you are using a different component, the COM injector vs the base COM port component.
In v7 the base COM port component can be found in the Component Search under the Misc category.
