Build Your Own ILI9163 gLCD SPI Component
Posted: Tue Aug 08, 2017 3:25 pm
by johnsondav
Hi Everyone
Here is a component project to enable you to build your own gLCD display component using the SPI port. You are able to insert your own command codes and configure the LCD control logic to suit your own needs.
I have included a tutorial (Draft) to help with your component build.
Please help and improve where possible, as I hope success will lead to various display components to be produced and hopefully shared.
The base gLCD display component project:
glcd_base_spi.fcfx
(105.27 KiB) Downloaded 619 times
The tutorial to help guide the component building process:
LCD Tutorial Project.pdf
(1.46 MiB) Downloaded 691 times
All constructive comments welcome.
Dave
