ERRATA - dsPIC33EP512MU814 (solved)
Posted: Thu Aug 24, 2017 10:00 am
by Brendan
We're attempting to code a test fixture around dsPIC33EP512MU814, but device definitions is clearly incorrect.
For example, Flowcode7 affords selection of Port 'I' but no such port exists on the chip, and port K doesn't show up but does exist.
Recalling that we had similar previous issues with a 32-bit PIC, which included UART issues (etc), I'd be very grateful for an overhaul of the definition file for this device so that we can continue.
Many thanks,
Brendan
Re: ERRATA - dsPIC33EP512MU814
Posted: Thu Aug 24, 2017 3:45 pm
Hi Brendan,
Thanks for letting us know. I thought we ignored port I but I am also getting the issue here so maybe this has been dropped or forgotten. Edit - Aha the STM32 devices do have a PortI so it looks like the change was maybe made to accomodate these.
Anyway here is a new definition file that should solve the problem for you. I'm making a new pass through the definition files now to fix other devices with the problem.
Simply copy the file to your "Flowcode 7\FCD\PIC16" folder and restart Flowcode.
Posted: Thu Aug 24, 2017 5:17 pm
by Brendan
Hi Ben.
Our HUGE thanks for the quick turnaround and updated file - Entirely appreciated, as always
All the best,
Brendan
Posted: Fri Aug 25, 2017 9:04 am
by electronix
Hi Ben.
Will you make a list of wich decvices you find? Since I have had some problems with dsPIC33ep512MU810, perhaps something similar to the mu814 issues.
Posted: Fri Aug 25, 2017 3:43 pm
I've posted all my modified definitions here.
viewtopic.php?f=63&t=18760
For the record these were the devices with the same problem.
- DeviceMod.jpg (97.53 KiB) Viewed 4948 times
That device was not in the list, what sort of problems have you been having?
