STM32F469 discovery cannot compile WLAN component
Posted: Tue Sep 05, 2017 6:17 pm
by achillis1
hello,
I try to send a blank flowcode to the STM32F469 screen and it compiles correctly.
When I add the wlan esp8266 component then I get an error; I attach it.
Thank you
Best Regards
Andreas Achilleos
Re: STM32F469 discovery cannot compile WLAN component
Posted: Tue Sep 05, 2017 8:59 pm
by LeighM
Could you attach your example, it might be a properties issue, such as uart channel?
Posted: Wed Sep 06, 2017 2:57 pm
by achillis1
Hello Leigh
I am attaching the file but I think is best to send me a file that you know is correct.
The file I am sending is blank and only the wlan component is added
I get the same error with every compination. For example, usart channel 1, channel 2 ,wlan macro added "initiate ()", baud rate 9600.115200, Tx Rx pin remap or not.
Thank you
Posted: Wed Sep 06, 2017 3:23 pm
by LeighM
Works for me, maybe you have older files, there are updates here...
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=18760
Latest attached, FCD in particular.
Could you try these.
Leigh
Posted: Tue Sep 19, 2017 4:00 pm
by achillis1
Hello Leigh
Thank you for the reply.
What about the .fcdx & .fcpx extension files? They are not recognizable by Flowcode.
Thank you
Posted: Tue Sep 19, 2017 4:25 pm
by LeighM
*.fcpx need to be copied into you Flowcode components directory
*.fcdx need to be copied into you Flowcode FCD\ARM directory
