nrf24L01
Posted: Mon Oct 23, 2017 6:37 pm
by dedajozo
I'm triing to make nrf24l01 transciever and reciever. Interesting this is that everything worked, but it stoped, and I cant make it to work again.
Can somebody take a look at the programs.
Predajnik is TX
Prijemnik is RX
THX
Re: nrf24L01
Posted: Tue Oct 24, 2017 12:11 am
by electron67
I also did the same thing, I did my own TX and RX and excellent work with the example published in Wiki, I work as 3 continuous transmissions, after that I could no longer run the nRF24L01. . . :!:
Enrique
Re: nrf24L01
Posted: Tue Oct 24, 2017 5:30 am
by dedajozo
My worked about 15 minites. I tried with osciloscope and i have oscilations , but like they are not working om same chanel.
Re: nrf24L01
Posted: Wed Oct 25, 2017 1:43 pm
by dedajozo
No one with expirience with nrf? Benj?Medelec?
Re: nrf24L01
Posted: Wed Oct 25, 2017 3:45 pm
I wrote the component based on an Arduino library to the point where it was working nicely. I haven't seen the suddenly no longer working problem and it was certainly up and running for a fair bit longer than 15 minutes.
Could it be something to do with voltages? Is the module powered at 3V3? if so then what voltage is your microcontroller I/O running at? If it's running at 5V then it could be that which is damaging the module over time.
A simple way to shift your 5V outputs to 3V3 is to use potential dividers on each output pin (CE, CSN, MOSI, CLK). MISO is an input pin so potential divider is not needed for this one.
https://a.pololu-files.com/picture/0J14 ... e8ec7aa643
