solving tmr0 related issues
Posted: Wed Oct 25, 2017 11:42 am
by kokoeike
Dear All,
I developed interest with this graphical programming software and i have since been brushing up my skills. well, i am currently working on a POWER MANAGEMENT SOLUTION; that will switch OFF and ON Air Conditioning units intermittently. the switching is time based (user settable).
my challenge: the code repeats the first switch loop on start-up and afterwards retains normalcy, but repeats this same issue after about 4 to 5 swiches. i need some help understanding where the problem is??? is it tmr0 related or designation related???
thank you.
Re: solving tmr0 related issues
Posted: Wed Oct 25, 2017 12:06 pm
Please can you attach your program file so we can see what you're doing and can you explain what the issue is?
Posted: Wed Oct 25, 2017 12:20 pm
by kokoeike
Benj wrote:Hello,
Posted: Wed Oct 25, 2017 3:53 pm
You have posted a topic in the Flowcode 7 forum but the file you posted is Flowcode 5 or previous. Please can you tell us which version of Flowcode you're using.
Also please can you explain what the problem is you're having?
Does the same problem happen in simulation?
Posted: Thu Oct 26, 2017 8:22 am
by kokoeike
i am using flowcode5 and haven't upgraded to a 7 yet.
the problem i experience doesn't surface while simulating via the software but is only noticeable on the hardware simulation.
the "SWITCH=1" loop repeats twice after the first timer expiration "Runtime".
now, the code is meant to enter SWITCH=1 loop on startup and after the "RUNNTIME" expiration, it should go into the second loop SWITCH=2 intermittently. i am using tmr0 for the timing at 1:64, 4Mhz.
the "SET" and "MODE" buttons are used to set default and new values for the timing.
the "MANUAL" and the "AUTO" buttons are used to enter AUTO MODE "WERE THE CONTROLLER DOES THE SWITCHING" and MANUAL MODE "were the controllers functionality is bypassed".
Benj wrote:Hello,
Posted: Mon Oct 30, 2017 2:41 pm
by kokoeike
thanks,
i have been able to resolve the issue. thanks for your response.
kokoeike wrote:Benj wrote:Hello,
TIME DEPENDENT PRIORITY AC CONTROLLER for DOWNSTAIRS.fcf
