Interrupt routine not being called
Posted: Sun Oct 29, 2017 11:54 am
The project i have been working on has failed to work with some real basic functionality i have used numerous other times. I have gone back to basics and created a simple flowchart. Even with this i cannot get the expected results in simulation or on hardware.
The flowchart is set up with an interrupt for timer0. When this overflows it should call an interrupt routine. In this routine it should toggle the LED A3 each time the routine is accessed. In the main loop there is another LED A2 that is also toggled each program cycle. If this section of code for toggling LED A2 is disabled the interrupt routine is never called and neither LED will flash. However if the code for flashing the LED in the main loop is enabled the interrupt routine is called and both LEDs flash.
I have tried opening the same flowchart in FC6 without the section of code for the LED A2 being present in the main loop and the interrupt routine is called without any issues.
I have tried completely uninstalling FC7 and reinstalling again but this has had no effect.
I cannot seem to find an explanation for what is going unless there is an some issue with my PC or an oversight on my behalf
