EEPROM/Console!
Posted: Sun Oct 29, 2017 6:40 pm
by jgu1
Hi again!
I was testing the EEprom example from help menu. I am not able to see the console when I simulate. I start the simulation go in wiew click on console,
but nothing happen, cannot see the console.?
If I do the same in FC6 it work. Am I doing something wrong, please? any idea?
Br Jorgen
Re: EEPROM/Console!
Posted: Sun Oct 29, 2017 11:43 pm
Hi Jorgen,
I assume you can't see the console window at all?
First make sure your up-to date with the latest files from here.
If not up-to date, then after updating, restart Flowcode.
If up-to date then sounds like the window position is out of normal range.
You could try using WINDOW menu, then select Restore window layout, the select Default.
Re: EEPROM/Console!
Posted: Mon Oct 30, 2017 5:03 pm
by jgu1
Hi Martin!
Thank´s for your reply. I have the latest update (240817), and yes, it could be it the Console out of the window/screen.. I try your suggest.
Went in window, click on > "restore window layout > Click on "standard" and I see some change happen, but I am still not able to see Console during simulation. I also try to go in wiev > Global option > Restore to standard, but no luck. Please any other suggest Martin. Thank´s in advance.
I have the same issue on both my PC.
Br Jorgen
Re: EEPROM/Console!
Posted: Tue Oct 31, 2017 5:31 pm
Hi Jorgen,
When you click Help -> View Licenses do you have a license for the TestDbg option?
If you don't then Flowcode should be generating a warning message saying something like "you don't have a license to view the console window".
Re: EEPROM/Console!
Posted: Tue Oct 31, 2017 8:03 pm
by jgu1
Hi again Ben!
Ok seemed not? But I get no warning?. But Ben, such a simple function as the console, would it not be obvious to be able to see and read the values ​​in EEprom in Console regardless of license as in previous versions?
If not, do you know the price and how I do the upgrading for the console? Please-
Br Jorgen
