Sending commands via SPI
Posted: Wed Nov 01, 2017 8:55 pm
by Tony Brown
Im trying to send a four bit command to an eeprom to make it format itself. I am using a pic 12f1840. When I monitor the SDO on a scope there is no data transmitted. Can anyone help?
I have attached the flowcode file.
Many thanks
Tony
http://www.flowcode.co.uk/mmforums/downl ... w&id=24848
Re: Sending commands via SPI
Posted: Mon Nov 06, 2017 11:31 am
Hi Tony,
Your program seems to have 3 SPI components in it. Maybe get rid of the components your not using.
If your going to monitor the SDO pin with the scope then try adding a while 1 loop around the send byte component macros to ensure your not simply missing the data.
What EEPROM are you using?
Posted: Mon Nov 06, 2017 9:28 pm
by Tony Brown
Thanks for your response.
The eeprom I'm wanting to erase is an AT45DB321D.
The eeprom needs a four byte command sequence: C7H, 94H, 80H and 9AH.
I have not used the SPI command before so any help will be most appreciated.
Regards Tony
Posted: Sat Dec 29, 2018 6:00 pm
Hi Tony,
I know this topic is over a year old, but did you resolve your issue?
