Zero crossing detector hardware.
Posted: Sat Nov 11, 2017 3:48 pm
by alanwms
If you want to pick up the zero point of the AC mains, a novel method (see attachment) is to use an opto isolator with two emitters reverse connected in parallel. The only time a positive signal is available, is when both LED emitters are not conducting (mains is at zero).
RB0 interrupt will be evoked every time the AC gets to a zero condition.
The main transformer uses a diode to supply the rest of you circuitry via the 5v regulator so no extra transformer is required.
Uses -
Light intensity control
Accurate timing (divide by 50 for 1 second action (60 USA)
Counting
Mains synchronizing (Grid inter-tie etc)
State programming - Allows an interrupt to gather I/O information. Could eliminate the requirement to use input icons making the program easier to read.
State Machine.jpg (59.54 KiB) Viewed 6146 times
Re: Zero crossing detector hardware.
Posted: Sat Nov 11, 2017 3:54 pm
by kersing
It would be nice if you could attach a flowchart to complement the screen shots. Screen shots can be hard to read...
Posted: Sun Nov 12, 2017 1:26 am
by alanwms
Not sure if my particular code will add anything so I have increased the resolution for a partial look at the development of "states" in the interrupt routine which can be used to determine what to do in the main program.
