ICD Question
Posted: Sun Jan 14, 2018 5:35 pm
Hi Team
I am confused but also very happy the firts time in a few years I am having FC and the ICD I see it operate as I would expect it too
This also brings a few questions and concerns up in my mind.
I am not sure why it is working so well on the PIC16F1937 -I see things with this chip and the ICD which I in the past on other devices gave up on FC and just did it in MPLAB,Now is this because you use this chip on your EB006 boards and made sure it is working and did not give such attention to the other chips
(1)Why I am saying /asking this is in the pass on other devices I never could get the ICD to follow through the Code on the chart once I use a C call component.the ICD will pop into the code in the C Call and then never come out and go to the next FC component.As you will see now on the attached the ICD goes into the C call execute the code and come out from it and go to the next FC Component
(2) I could never get to see the variables use used in the C Call in the debug window now I can set a break point and see a variable in the C call update
I am not complaining I am very happy
to see this happen ,If it will work like this on all other chips there is no reason to use any other tool
Please can you too explain me if what I see is the way it should work? if then what could be the reasons that I was never able to do this on various other PIC 8 bit chips ?
I like how FC is working on the PIC16F1937
