P16F1704 PWM Component Not Working [Solved]
Posted: Sun Jan 28, 2018 6:29 pm
Hi All.
I am having problems to get the PWM component on a PIC16F1704 to work in Flowcode.
I have configured the device with the MCC in MPLAB and the PWM runs perfectly attached the MPLAB project with the generated
configurations and the FC Flowchart for reference.
as you will see I have configured the PWM component in FC exactly as in MCC and there is no output from the PWM .
Here the output from MPLAB generatde hex file
The project files The FC configuration
Interesting is that the 1704 only has PWM channels 3 and 4 in HW, however Flowcode allows me to select Channel 1 -4 ,however the correct config is shown a above .my feeling is that the PPS is not set correctly for the Pins I might be wrong however it would be great if you guys could find the issue
and help out here.I also tried both setDuty and setDuty10bit no result
Please help
Please help
