Youth deterent!
Posted: Tue Feb 20, 2018 5:39 pm
by jgu1
Hi!
I am trying to create/convert the "youth deterent" from Bert v Dam´s book from FC5 to FC7. But when I compile the program I get "error code 1"
and it have something to do with tmr0, I use the C command: tmr0=0x195;
It work in FC5 but not in FC7. Can anybody tell me what I am doing wrong please?
Br Jorgen
Re: Youth deterent!
Posted: Tue Feb 20, 2018 6:05 pm
Hi Jorgen,
In v7 you need to capitalise the register name to work with the xc8 compiler.
TMR0 = 0x195;
Also your value looks wrong, should this be 195 instead of 0x195? 0x195 is a 12-bit value and the TMR0 regiser is an 8-bit register.
Re: Youth deterent!
Posted: Tue Feb 20, 2018 6:33 pm
by jgu1
Hi Ben!
Thank´s again for REALLY fast reply. And it work. :D
Br Jorgen
Re: Youth deterent!
Posted: Tue Feb 20, 2018 6:42 pm
Hi Jorgen,
Deterrent will not work on hardware unless you change Clock source select within Interrupt properties from:
Transition on T0CKI pin
to
Internal clock.
Otherwise intrerrupt will be waiting for a change on T0CKI pin.
Re: Youth deterent!
Posted: Tue Feb 20, 2018 8:02 pm
by jgu1
Hi Martin!
No I see now when you spotted this, of course, thank´s. I have to test it later on hardware. I could not understand why I not was able to compile.
My goal is, to create random frequencies from16Khz to 40Khz in approx. 2-3 kHz step. I have to measure how high the freq is if I set TIM0 to:
TMR0 = 0x254;
Thank´s Martin for spotting.
Br Jorgen
Re: Youth deterent!
Posted: Tue Feb 20, 2018 9:25 pm
Your welcome.
jgu1 wrote:TMR0 = 0x254;
You have got that wrong!
Values are:
Decimal:
TMR0 = 0;
to
TMR0 = 255;
or
Hex:
TMR0 = 0x0;
to
TMR0 = 0xFF;
Although in practice you would not go too near the highest value of dec 255 or hex 0xFF
