Hi Ben,
I've written about this topic in the following post:
http://www.flowcode.co.uk/mmforums/viewt ... =2&t=19766
Unfortunately, it did not improve with 7.3.0.7 update, so I'll re-issue this problem.
I would like to use ICT function of FlowKit2.
In the Flowcode 7.3.0.5 or higher version, in the ANALOG section of the ICT function, the inputs can not be activated.
Can not assign FlowKit 2 inputs for analog channels of the PIC24FJ256GA106 microcontroller in this case.
(The number of inputs offered by Flowcode depends for the type of the selected microcontroller.)
In the DIGITAL part, you can assign ports from only a reduced list to the FlowKit 2 Dx inputs.
Is there any medicine for this?
Best Regards,
Lagoda
Port mapping bug in the ICT module.
