Extracting portions of data from Circular Buffer
jollybv
Flowcode v5 User
Has thanked: 81 times
Been thanked: 25 times
Post by jollybv »
Hi Guys
I'm trying to extract say for example the phone number from the circular buffer, What i need is to scan the buffer until i see the " then read the 12 digits and exit but i cant seem to be able to get this right any help / examples will be appreciated as system must go out on Monday. I've tried using string manipulation but is not efficient as different networks have different formats.
+CMT: "+27741016705",,"2018/04/21 09:32:31+08"
+CMT: "+27741016705" Please call
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Extracting portions of data from Circular Buffer
Post by mnf »
Please give us a little more detail of what you are trying to do. Save the characters to a string, convert to a number (or several numbers) is there any detail in the string etc
The circular buffer allows easy access to contents using GetByte, and of you've downloaded the latest version of the component then there is a PeekByte which will let you check for the end of a symbol too.
jollybv
Flowcode v5 User
Post by jollybv »
Hi Martin
Thank for the response what I'm trying to do is extract the 12 digit phone number (+27741016705) out the string in the buffer and compare it with a number stored in memory. the comparison is not a problem it is getting the 12 digit number as the buffer is constantly getting updated and never the same size to use string manipulation
jollybv
Flowcode v5 User
Post by jollybv »
Hi Martin
Thank for the response what I'm trying to do is extract the 12 digit phone number (+27741016705) out the string in the buffer and compare it with a number stored in memory. the comparison is not a problem it is getting the 12 digit number as the buffer is constantly getting updated and never the same size to use string manipulation.
Do you have a link where i can download the updated component.
mnf
Post by mnf »
Something like :
[img]buffer.PNG[/img]
How is your circular buffer being updated - if interrupts? - you may need to disable them whilst reading to .data (which you are then free to compare etc as required)
How big a buffer are you using ?
The updated circular buffer component (thanks to Ben for this) is at http://www.flowcode.co.uk/mmforums/downl ... p?id=25485
(23.87 KiB) Downloaded 1951 times
jollybv
Flowcode v5 User
Post by jollybv »
Hi Martin
Thanks for this I can see exactly how it will work
