MATRIX MIAC Programmer SW
Posted: Fri Jun 15, 2018 6:11 pm
Hi Team.
I am having an issue with programming a MIAC in the field far away from me
The MIAC Connects to the programmer load the hex file(which programs perfectly out of FC7 and FC8) then starting to program but then an error regarding the eeprom is made and the programming stops with the progress bar at the position as you see in the attached ,
What are we doing wrong ? On the other side it says sending completed I am not sure now is the MIAC programmed or not, as it is connected to a very expensive Test rig, I am afraid to start the system not knowing the MIAC is programmed Correctly
Please help
Please help
