Page 1 of 3
MOD Operation selected after Minut
Posted: Tue Jul 03, 2018 9:39 am
by Monie Jacobsen
Hello Everbardy
User Flowcode v8
Can I use MOD Operation for the following:
Want to be selected after Minut as 0,15,20,25,30,35,40,45,50,55
How to MOD output becomes 1 by only the specified Minut above!
Would you like to help with a code example.
Or do you have a bathers suggestion, please with a code example?
Re: MOD Operation selected after Minut
Posted: Tue Jul 03, 2018 10:32 am
by LeighM
- minutes.jpg (13.17 KiB) Viewed 27422 times
Posted: Tue Jul 03, 2018 10:39 am
by Monie Jacobsen
LeighM
It was good I asked you.
I did not show you could as you suggested.
Thank you very much
GO Working day
Posted: Tue Jul 03, 2018 11:53 am
by Monie Jacobsen
Hello Everbardy
Can not turn off RelayOFF(1) after 30 s
Inside GPS Data
- GPSTrackingPeriode.JPG (23.7 KiB) Viewed 27416 times
[/attachment]
- Turn off relay.JPG (59.67 KiB) Viewed 27416 times
Please see here!
Attached: [attachment=1]MIAC dsPIC Tracking Test.fcfx
Do you have a suggestion that relay can go off?
Have tried many options but without luck!
Posted: Wed Jul 04, 2018 11:22 am
by Monie Jacobsen
Hello Everbardy
Can not turn off RelayOFF(1) when I wish this.
Have tried a lot that after RelayON (1) to set RelayOFF (1)
But only after a full minute, Relay 1 turns off.
Is there anyone here that has a suggestion for how to switch off Relay 1 (RelayOFF (1) for example 30 sec.
Posted: Wed Jul 04, 2018 12:29 pm
by LeighM
Hi Monie,
I have not had chance to look at your program, but if your program is continuously looping to the "if Minutes % 5" icon, then it will go down that branch many times during that minute, until the next minute.
So if you only want to do something once every 5 minutes, then you will need to set a flag once it has been done, then add another test and skip if the flag is set.
Or alternatively, ensure that the "Minute % 5" test is only done when the Minute changes.
(e.g. Compare two variables, PreviousMinute and Minute)
Posted: Wed Jul 04, 2018 12:38 pm
by Monie Jacobsen
Hi LeighM
Thanks for the answer.
Test your suggestions.
Posted: Wed Jul 04, 2018 2:08 pm
by Monie Jacobsen
Hi LeighM
I can not stop the current TrackingPeriode% 5 = 0
What am I doing wrong?
- PreviousMinute.JPG (42.61 KiB) Viewed 27381 times
Posted: Wed Jul 04, 2018 3:34 pm
by LeighM
- do_once.jpg (30.31 KiB) Viewed 27376 times
Posted: Wed Jul 04, 2018 4:10 pm
by Monie Jacobsen
Hi LeighM
Thank you very much for the help, this works.
Posted: Wed Jul 04, 2018 4:54 pm
Hi Monie,
I have also made some changes for you to try.
Main reason for change is if you have a 30 sec delay then nothing else will happen during the delay so you won't see the seconds increment on the display, should you wish to add it?
At least you can see the seconds ticking up.
To get around that we can use the seconds from GPS to use as a 30 second timer.
I have also change the setting on your interrupt to make it much more accurate if you decide you wish to use it.
I used:
Posted: Thu Jul 05, 2018 8:16 am
by Monie Jacobsen
Hi medelec35
Thank you very much for your proposal for the codes.
Everyday suggestions to see the codes in a different way.
And not least, your suggestion for Interrupt Ur codes, very fine
Have a go day
Posted: Mon Jul 09, 2018 11:20 am
by Monie Jacobsen
Hello Everbardy
User dsPIC Miac
Is there anyone here that will help with the following problem?
Want to read incoming pulses Until FREQUENCY = 125 and then stop reading.
Please see the code below!
Posted: Mon Jul 09, 2018 12:13 pm
Hi Monie,
You are using the wrong principle to measure frequency.
You have a timer interrupt which will be a value between 0 and 65535 and is incrementing all the time..
However since you have assigned an input which will only be 0 or 1 to the same variable then whatever value the interrupt will reach,
as soon as Digital input is reached then interrupt value will change to 0 or 1.
You will be able to see the variable counting if you disabled the input.
For a frequency counter, A timer interrupt is required to time for 1 second.
INT Interrupt is used so its triggered with input on INT pin changes from 0 to 1. Use a different variable to timer interrupt.
1) Set variable (e.g IntCount) within INT interrupt to 0 & Reset Timer variable within a code block.
2) When 1 second has elapsed, make a different variable E.g Frequency = IntCount.
Frequency variable is of course the frequency this can be displayed on an LCD.
3) Go to step 1.
I can help you implement the above if you get stuck, but I'm not as familiar with Dspic as I am with PIC.
Posted: Mon Jul 09, 2018 2:07 pm
by Monie Jacobsen
Hi medelec35
You can very much help me with an example
I am stuck...
Would like to have an example that I can work on...
Posted: Mon Jul 09, 2018 10:54 pm
Hi Monie,
Attached is a very basic frequency counter.
Connect signal to RB0.
Posted: Tue Jul 10, 2018 6:30 am
by Monie Jacobsen
Hi Everybody
Thank you very much for the codes
But where goes wrong?
Is there anyone here that can describe what should be done in the codes to make it work
Want input to InoutDIGITAL(7)
For error message see below!
Target folder: C:\Users\Bruger\Desktop\TILFOR~1
Source name: C:\Users\Bruger\Desktop\Til Forum\READ FREQUENCY_dsPIC Miac v1a.fcfx
Title:
Description:
Device: PIC16.33E.MIAC (dsPIC) System
Generated by: Flowcode v8.0.0.6
Date: Tuesday, July 10, 2018 06:10:08
Users: 1
Registered to: monie jacobsen
License key: X6U4U7
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat "READ FREQUENCY_dsPIC Miac v1a" "C:\Users\Bruger\Desktop\TILFOR~1\" "33EP256MU806"
C:\Users\Bruger\Desktop\TILFOR~1>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "READ FREQUENCY_dsPIC Miac v1a".c -o "READ FREQUENCY_dsPIC Miac v1a".o
coff-gcc.exe: READ FREQUENCY_dsPIC Miac v1a.c: No such file or directory
coff-gcc.exe: no input files
Error returned from [xc16-gcc.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
Posted: Tue Jul 10, 2018 7:44 am
Hi Monie,
You're welcome.
Sorry, I added an extra space between c of Miac and v.
Did not know it would cause an error.
If you delete the extra space, then your flowchart will compile OK.
Monie Jacobsen wrote:Want input to InoutDIGITAL(7)
Select properties of INT2, then withn properties click on the properties.
In the Remapped Pin Selection, change RB0 to the desired input pin.
Posted: Tue Jul 10, 2018 8:28 am
by Monie Jacobsen
Hi medelec35
add an extra space between c of Mac and v.
Where does this happen to her, can not find
Where is the "extra space between"
Posted: Tue Jul 10, 2018 9:11 am
Posted: Tue Jul 10, 2018 10:51 am
by Monie Jacobsen
Hi medelec35
Thanks for the fix;-=
But I can not see any frequency in dsPIC MIAC in the Display??
Have chosen counting entries as: I6 = E1.
Get no display in Display only "0"
- Simulering.JPG (22.23 KiB) Viewed 27259 times
Posted: Tue Jul 10, 2018 12:23 pm
How are you simulating incoming pulses?
You can only toggle RB2 (no matter what the pin mapping for INT2 is set to) on flowchart to simulate pulses.
It will not work very well with that side of things.
Best to test with hardware.
Also D7 (I7) will not work
You can only use an input that can be selected from the INT properties.
So only inputs I1 to I5 will work.
If you want to measure pulses on I1 for example then within INT2 properties select RB0
I don't know much about dsPIC version of Miac, only what I have seen on the flowchart.
Maybe someone who knows them well can assist further?
The attached flowchart will simulate an external input.
The display will not be steady like it will be on actual hardware as with simulation, the C icon will not be clearing TMR1 register.
Posted: Tue Jul 10, 2018 12:29 pm
Posted: Tue Jul 10, 2018 1:08 pm
by Monie Jacobsen
Hi medelec35
It works very fine now
With pulses on I1, and selected to INT2 / REMAP-
and port number RB0 seems to read the frequency fine now.
I wish to use I5 Port No.?
What form did you use to find I1 and selected INT2 / REMAP-port number RB0 ?
Thank you very much and your patience.
Posted: Tue Jul 10, 2018 1:29 pm
Glad you are now able to read pulses OK.
Monie Jacobsen wrote:Thank you very much and your patience.
No problem.
I believe datasheet requires changing to make this clearer!
Nothing wrong with adding I1 = RB0 & An0, I2 = RB1 & An1, I3 = An2 & RB2 etc.
I3 to I8 could be added to chip diagram as I1 & I2 are already present.
What I did was View Chip then View Analog Inputs.
Ran simulation.
I assumed AN0 = I1 ...........AN7 will be I8.
Ran simulation then moved An0 slider which causes the corresponding pin on the chip diagram to change from black to yellow = RB0
Did the same for all the other analog inputs.
