FC8 Language problem
xelites
Been thanked: 7 times
Post by xelites »
Hi, I have installed Flowcode 8 and I have a question and one problem.
Question: Can I open programs made with FC7 directly or do I need to import them?
Problem: I can not change the language in any way, I can only choose between English French and German! all the others do not come out ... how can I solve?
Thanks, I'm waiting
Re: FC8 Language problem
Import is for older versions of flowcode,
With V7 you just use open,
If issue with Language then does sound like a bug.
For that reason I have moved topic to V8 bugs section.
If it turns out not to be a bug, will move topic back again.
xelites
Post by xelites »
thx medelec35, now it remains and I confirm the bug of the language I have tried two installations on different computers and the problem is the same I wait info from the support.
Thanks to all good work
Gabriele
Flowcode is currently only available in English, French, German and Spanish. We are considering adding Italian to this list but it is not trivial to add another complete translation to Flowcode.
Is there any particular language you would like to see?
xelites
Post by xelites »
Ok Steve if and when you can in Italian was enough :-) because the FC7 had it.
I continue to use it in English no problem.
Thank you
Osta
Been thanked: 13 times
Post by Osta »
Hello dears!!!
Confirm the problem with the language!!!
I have a request - please bring back the Russian language!!!
It is very necessary!!!
Thanks in advance!!!
