eBlocks2 simulation
Posted: Mon Sep 24, 2018 9:01 pm
by Blinky
Hi everyone.
I am teaching a class using the unit 6 intro to microcontrollers, however, with the eBlocks 2 modules such as the BL0145-1 switch board, is it possible to use the buttons within the simulation? If not, what are the alternatives.
Many thanks
BlinkY
Re: eBlocks2 simulation
Posted: Mon Sep 24, 2018 9:19 pm
Hi Blinky,
Yes you and either use the actual BL0145 (Eblocks Menu) or with switch array template (Inputs menu)
If your not sure where to find the components for simulation, just select the search icon on the left then enter a few letters.
E.g sw
What I like to do is add the switches to the 3D panel, so I can change the angle for easier viewing.
If you require further help then let us know.
Posted: Tue Sep 25, 2018 12:59 pm
Hi BlinkY,
I've provided a quick example to show the EB2 component sim working.
EB2_SW_LED.fcfx
(8.26 KiB) Downloaded 532 times
