I2C Compile Error
Posted: Sat Oct 27, 2018 12:58 pm
by linktech
Hi, i also have same issue when compile HEX file , when i was connected with I2C LCD display 16x2 with arduino UNO R3 and Arduino MEGA 2560 R3 I try both arduino board is same error when i was compile.
Please need technical support
thanks
Re: I2C Compile Error
Posted: Sat Oct 27, 2018 1:06 pm
There is know issue older versions of V7.
Have you updated by going
here?
Posted: Sat Oct 27, 2018 4:00 pm
linktech,
you have posted 3 posts stating the same error.
I have deleted the other two posts.
If updating V7 with the latest files as stated above does not work, then I will move this thread to V7 bugs section.
What Version of V7 (Help, About Flowcode) are you running?
