compiler errors when using the WS2811 in FC8
Posted: Mon Nov 26, 2018 9:39 am
by EFB
When I compile using the WS2811 component I get the following errors:
Test.c: 507: (192) undefined identifier "T1LNOPSDEF"
Test.c: FCD_06621_LED_WS2811__Refresh()
507: } else {
^ (312) ";" expected
Test.c: 542: (192) undefined identifier "T1LNOPSDEF"
542: } else {
Test.c: 577: (192) undefined identifier "T1LNOPSDEF"
577: } else {
(908) exit status = 1
Error returned from [xc8.exe]
This only happens when I compile with FC8?
When I compile the same with FC7 all works fine.
I updated FC8 and al components but no luck.
Thanks,
Evert
Re: compiler errors when using the WS2811 in FC8
Posted: Mon Nov 26, 2018 1:10 pm
Hello Evert,
Thanks for letting us know.
I've fixed the problem and will get the fix pushed to the updates system in the next 10-20 minutes for you.
Posted: Mon Nov 26, 2018 3:24 pm
by EFB
Update workt perfect!!
Thanks for the quick repair.
Evert
