USB in Flowcode 8
VladimirRepin
Has thanked: 1 time
Been thanked: 3 times
USB in Flowcode 8
Post by VladimirRepin »
I have a problem with creating a program using USB component from E-blocks.
I have 18F4455 chip and Flowcode 8.
I cant compile a hex-file if I have any USB component(HID, Serial, ...) in the program. Even if I don't use macros.
Could you help me with my problem?
Thanks in advance for reply.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: USB in Flowcode 8
Post by QMESAR »
Hi.
Please post your flowchart that the people can take a look at it and try to reproduce the error,I am using USB in FC8 with no problems.
VladimirRepin
Has thanked: 1 time
Here it is.
USB_FlowcodeV8.fcfx
(10.48 KiB) Downloaded 239 times
QMESAR
Post by QMESAR »
Vladimir:
You project(Flowchart) compiles fine with me in FC 8.1
What FC version are you using ? can you post a print of the errors reported when you compile
see below your chart compiled with me
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
VladimirRepin wrote:I cant compile a hex-file if I have any USB component(HID, Serial, ...) in the program.
Make sure you use FC 8.1 with the latest updates. The initial FC 8.0 release has issues with the USB for some controllers, this was fixed in updates. However you are unable to update 8.0 now 8.1 has been released so you need to update to 8.1 if you haven't done so yet.
― C.S. Lewis
