EEPROM component improvement
CamargoF
Has thanked: 6 times
Been thanked: 7 times
Post by CamargoF »
I would like to proposed an improvement on EEPROM module where the initialization should be done on multiple lines with 3 columns:
  • The first column is optional, for an alias label that could be used later on programming.
  • The second column is the EEPROM address, always considering the first EEPROM address as 0x0000.
  • The third column is the data to be stored in EEPROM, with the same syntax of current initial values.
If it is not possible do be done on short time, at least provide a C code template to allow the EEPROM initialization on program.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: EEPROM component improvement
Post by kersing »
Initialisation is already available in the "Initial values" property. You can enter values starting at the first eeprom byte. Check the bottom of this manual page for syntax.
― C.S. Lewis
