Settings for ATmega328P
Oderlando
Has thanked: 7 times
Been thanked: 3 times
Post by Oderlando »
Hello. To date I have used PIC drivers. But recently, I decided to explore an ATmega328P (No Arduino bootloader). I tried to make a flashing LED but I did not succeed. I am using an 8MHz crystal, but I do not understand the settings of this microcontroller. There are several frequency options that seem to me to be several things repeated. Can anyone help me the right option to use an 8MHz crystal on the ATmega328P? I'm sending a print out of the screen. Thanks in case anyone can help me.
(326.81 KiB) Downloaded 824 times
Has thanked: 481 times
Been thanked: 699 times
Re: Settings for ATmega328P
The default setting should be OK for you.
You can drag the edge of the config dialog to see the full text...
