AVR lock bits
Posted: Thu Jan 03, 2019 9:58 pm
by iain wilkie
Is there a way of setting the lock bits in an AVR from within Flowcode ?
Easy to do using Avrdudess but would be handy if it could be done from within Flowcode.
Using an ATTiny261.
Cheers
Re: AVR lock bits
Posted: Mon Jan 07, 2019 12:28 pm
This certainly used to work from inside Flowcode with the AVRISPmkII but I must admit I currently also use AvrDudess whenever the need arises, it's fairly rare I use AVRs and when I do more often than not I use an Arduino with fuses already pre-programmed.
What programmer hardware are you using and I'll investigate for you.
Re: AVR lock bits
Posted: Mon Jan 07, 2019 1:00 pm
by iain wilkie
Hi Benj,
Currently using the AVRispmk2 programmer, but have ordered the tinyusb one from Matrix but it’s not here yet.
Once it’s here that (hopefully shortly) that will be my go to programmer.
Iain
