INQUIRY RE- MLOADER FAILING TO UPLOAD CODES TO BL0080 PROGRAMMER
Posted: Wed Jan 09, 2019 1:00 am
I have a problem uploading codes from FLOWCODE8 (ver. 8.0.0.6) to my BL0080 microcontroller board. I am not really sure if it is going to solve my problem but below please find the procedure about communicating with a device using USB. Any help regarding my problem is greatly appreciated. Thank you in advance.
Carlos
;This .inf file is a modified version of the example INF provided
;in the Microsoft document:
;"How to Use WinUSB to Communicate with a USB Device"
[Version]
Signature = "$Windows NT$"
Class = BL0080
ClassGuid= {a503e2d3-a031-49dc-b684-c99085dbfe92}
Provider = %MFGNAME%
DriverVer=01/06/2015,1.0.0.5
CatalogFile=BL0080.cat ;CAT file needed for a signed driver pacakage
; ========== Manufacturer/Models sections ===========
[Manufacturer]
%MFGNAME% = MyDevice_WinUSB,NTx86,NTamd64
; Vendor and Product ID Definitions
; When developing your custom USB device, the VID and PID used in the PC side
; application program and the firmware on the microcontroller must match.
; Modify the below lines to use your VID and PID. Use the format as shown below.
; Note: One INF file can be used for multiple devices with different VID and PIDs.
; For each supported device, append ",USB\VID_xxxx&PID_yyyy" to the end of the line.
; There is a maximum number of devices that can be supported per line however.
; If you append a large number of VID/PIDs to the end of the line, and get a:
; "The data area passed to a system call is too small." error when trying to install
; the INF, try removing some of the VIDs/PIDs.
[MyDevice_WinUSB.NTx86]
%DESCRIPTION% =USB_Install, USB\VID_12BF&PID_0027
[MyDevice_WinUSB.NTamd64]
;ClassInstall32 and ClassInstall_AddReg sections used to make new device manager category.
[ClassInstall32]
AddReg=ClassInstall_AddReg
[ClassInstall_AddReg]
HKR,,,,%DEVICEMANAGERCATEGORY%
HKR,,Icon,,"-20"
; =================== Installation ===================
; Right click - Install Added 27/05/15
[DefaultInstall]
CopyINF=BL0080.inf
[USB_Install]
Include=winusb.inf
Needs=WINUSB.NT
[USB_Install.Services]
Include=winusb.inf
AddService=WinUSB,0x00000002,WinUSB_ServiceInstall
[WinUSB_ServiceInstall]
DisplayName = %WinUSB_SvcDesc%
ServiceType = 1
StartType = 3
ErrorControl = 1
ServiceBinary = %12%\WinUSB.sys
[USB_Install.Wdf]
KmdfService=WINUSB, WinUsb_Install
[WinUSB_Install]
KmdfLibraryVersion=1.11
[USB_Install.HW]
AddReg=Dev_AddReg
[Dev_AddReg]
HKR,,DeviceInterfaceGUIDs,0x10000,"{58D07210-27C1-11DD-BD0B-0800200C9a27}"
;When editing the GUID (the big hex number with dashes inside the squiggly
;braces), make sure to write the intended PC application to use the same GUID.
;Otherwise the application won't be able to find the USB device properly.
[USB_Install.CoInstallers]
AddReg=CoInstallers_AddReg
CopyFiles=CoInstallers_CopyFiles
[CoInstallers_AddReg]
HKR,,CoInstallers32,0x00010000,"WdfCoInstaller01011.dll,WdfCoInstaller","WinUSBCoInstaller2.dll"
[CoInstallers_CopyFiles]
[DestinationDirs]
CoInstallers_CopyFiles=11
; ================= Source Media Section =====================
[SourceDisksNames]
1 = %DISK_NAME%,,,\i386
2 = %DISK_NAME%,,,\amd64
[SourceDisksFiles.x86]
WinUSBCoInstaller2.dll=1
WdfCoInstaller01011.dll=1
[SourceDisksFiles.amd64]
WinUSBCoInstaller2.dll=2
WdfCoInstaller01011.dll=2
; =================== Strings ===================
[Strings]
MFGNAME="Matrix Technology Solutions Ltd"
DESCRIPTION="BL0080 Ghost2 PIC DIL Programmer"
WinUSB_SvcDesc="WinUSB Device"
DISK_NAME="WinUSB Device Install Disk"
DEVICEMANAGERCATEGORY="Custom USB Devices"
Carlos
[Version]
Class = BL0080
[Manufacturer]
[ClassInstall32]
HKR,,Icon,,"-20"
[DefaultInstall]
CopyINF=BL0080.inf
[USB_Install]
Include=winusb.inf
Needs=WINUSB.NT
Include=winusb.inf
ServiceType = 1
StartType = 3
ErrorControl = 1
[USB_Install.Wdf]
[WinUSB_Install]
[USB_Install.HW]
AddReg=Dev_AddReg
[Dev_AddReg]
[DestinationDirs]
[SourceDisksNames]
[Strings]
