Hidden Flowchart icons
Posted: Mon Jan 21, 2019 6:15 pm
by STibor
Hello!
The 2D 3D window covers the left-hand flowchart icons.
Re: Hidden Flowchart icons
Posted: Fri Feb 08, 2019 6:33 pm
Yes we have changed the UI around a bit in v8.
Thanks for letting us know of the problem.
I'll see if this is something we can address for you.
Posted: Thu Apr 04, 2019 7:03 am
by STibor
Will there be a solution to the problem?
Thanks!
Posted: Thu Apr 04, 2019 3:37 pm
by DanielM
This is not actually a bug, but is due to the fact that the icon toolbar has been moved from a single global location (left of the main window), to be part of each individual programming view window. The reason why it is not fully visible in the screenshot shown is because the programming view is not big enough vertically.
However it can now be set back to the old position if you want. Please install the v8.1.1 hotfix from here (note that this requires v8.1 to be installed):
https://www.matrixtsl.com/flowcode/download/
In the Global Options window there is a setting called "Bind an icon toolbar to each programming view", which can turned off. This will reintroduce a single, global icon toolbar as seen in v8.0 and previous versions.
Daniel.
