ILI9341 SPI wont work
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Post by CSM2711 »
next display next Problem.....
I try to communicate wit a ILI9341 by use a PIC16F1827 but it wont work...
The only the backlight of the tft will light up :lol:
Maby someone can say me whats my mistake ?!?
analog_to_display3.fcfx
(11.11 KiB) Downloaded 208 times
CSM2711
Has thanked: 1 time
Re: ILI9341 SPI wont work
Post by CSM2711 »
OK, i found the Problem.
The supply voltage was higher then 3V ......
But the display is very very slow, I try to colorize the background by draw a rectangle with red background color but it will take along time ......
Has someone an Idea or is that normal for this type of display?
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
Hello CSM2711
Read: http://www.matrixtsl.com/mmforums/viewt ... 76&t=20410
Try the next:
1. Move the background colors/draw to init stage (out of the main loop).
2. The Clear iLi display function takes a lot of time, don't use it, just 'print' the empty space over the text (erase it).
3. Use for communication between the microcontroller and iLi9341 the level shifter.
PS
I use iLi with Arduino.
The display is good for my weather station, but not fast.
