DMX Slave receives nothing
Fer_taca
Has thanked: 13 times
Been thanked: 10 times
Post by Fer_taca »
I have a slave in DMX but I do not receive anything.
What am I doing wrong?
dmx.fcfx
(9.22 KiB) Downloaded 199 times
Re: DMX Slave receives nothing
First have you done a 1 second flasher test to confirm your setup is correct.
https://www.matrixtsl.com/wiki/index.ph ... ED_flasher
Second are you running Flowcode 8.1 and updated to the latest version of the component using the Help -> Check for updates menu. We recently fixed some bugs with the DMX component which you will need to proceed.
Fer_taca
Post by Fer_taca »
Thank you very much Ben.
Yes, I tried the hardware and it´s OK.
F.
