Display the value of a variable in simulation
DirkB
Has thanked: 7 times
Been thanked: 11 times
Post by DirkB »
how can I display the value of a variable in simulation,
e.g. the value of a pot or value of a timer?
thanks
Dirk
Has thanked: 187 times
Been thanked: 205 times
Re: Display the value of a variable in simulation
Depending on the component selected (e.g. potentiometer) you will see the value directly on the scale as you move it. However to see actual variable values in simulation you need to:-
Start the simulation - This will open the Simulation Debugger window
Pause the simulation
In Simulation Debugger window you can select the variables you wish to monitor under Expression > Add Variable
Start the simulation.
Be aware though that if your simulation speed is too fast you may not notice any change in variable(s), in which case either slow the speed or "Step Into" the program.
Hope this helps.
DirkB
Post by DirkB »
thank you for Reply, it works. Is it possible to
Display variable in realtime? In Flowcode V5
i have used the eeprom component to Display
e.g. pot or timer values.
Dirk
Simulation isn't really "real time" and is heavily based on PC performance but if the simulation speed is slow enough (or variables only change on specific events) then you can see them change in the Simulation Window without pausing.
Do you, or can you use the "Ghost" facilities of EB-006 programmer board? That is independent to your PC other than to read values and start / pause etc. Perhaps you could use that?
