RPI!
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
RPI!
Post by Monie Jacobsen »
Hi Team!
I just get a RPI3 board. Is there a guide how to use RPI with FC8. I remember I have seen (but don´t remember where) somewhere that I need to install some file/driver, maybe an examble. Please.
Hope you can help.
Best Regard
Monie
Re: RPI!
Hi Monie,
The document you want is probably the RPI getting started guide which is available towards the bottom of this page.
https://www.matrixtsl.com/flowcode/support/
Monie Jacobsen
Re: RPI!
Hi Benj
Thank you very much for the answer;-)
How to insert another background picture in RPI3 board?
Please a example step by step!
Best Regard
Monie
Has thanked: 481 times
Been thanked: 699 times
Re: RPI!
Hi Monie,
Do you mean to put an image on the HDMI output to screen?
If so, I've attached a quick example of using the Flowcode display and bitmap drawing components.
Leigh
RPI_HDMI_EXAMPLE.zip
(8.61 KiB) Downloaded 191 times
Monie Jacobsen
Re: RPI!
Hi Leigh
Yes it is as you type the HDMI output to screen
Thank you very much for your example;-)
I will immediately test your example and then print the proposal and save the suggestion as I always do.
GO'Working Day
Best Regard
Monie
