E-blocks 2 RFID Board (BL0197)
VladimirRepin
Has thanked: 1 time
Been thanked: 3 times
Post by VladimirRepin »
There is a problem with the RFID BL0197 component. This component is not initialized.
The component was connected to the BL0011 Board to B and C ports.
I used the RFID (EB052, RWD MICODE) component in Flowcode 8.2 and tried to set up different ports (B and C) in the connection setup. I set the TX to pin 0, RX to 1 and CTS to 4 (as in E blocks 2 datasheet).
I also tried using RFID (MFRC522) component but it didn't work. Port connection settings are different from that in the datasheet., so I do not think that use this component is correct.
How to use these settings in the right way?
(343.6 KiB) Downloaded 1672 times
Re: E-blocks 2 RFID Board (BL0197)
Here is a program you can try.
Connect a combo board to Ports A and B or an BL0169 LCD to Port B and connect the RFID board to Port C only.
EB2RFID.fcfx
(11.69 KiB) Downloaded 490 times
VladimirRepin
Has thanked: 1 time
Thanks, it really works.
I think the problem was that I set TX to 0 and RX to 1, but I had to do the opposite (TX to 1 and RX to 0).
