Building string in one or more steps
Posted: Sat Aug 03, 2019 7:30 pm
by Jan Lichtenbelt
I wanted a string which is the sum of 4 other strings.
First I did it in one step like
STRING = str1+ str2+str3+str4 (1)
This works in simulation, but gave the wrong result in practice with the microchip.
Buiding the string step by step results in the correct string. Like
STRING= str1
STRING= STRING+str2
STRING= STRING+str3
STRING= STRING+str4 (2)
What is the reason of the wrong results of (1)?
Kind regards
Jan
Test_Timer1_V3.fcfx
(11.16 KiB) Downloaded 310 times
Re: Building string in one or more steps
Posted: Sun Aug 04, 2019 5:33 am
by chipfryer27
Hi Jan
This is a known "feature" of Flowcode and has been brought up a few times. The recommended way to concatenate is how you did it in your working example.
I'm sure a search of the forum will explain why, and sorry that I don't have time at present to supply a link to such.
Posted: Sun Aug 04, 2019 8:31 am
by mnf
It 'compiles' to
    FCI_SHEAD(FCV_TEMPERATURE_STR,FCVsz_TEMPERATURE_STR, " ",2, FCI_TMP_STR,20);
    FCI_SHEAD(FCI_TMP_STR,20, FCI_TOSTRING(FCV_ALARM_TIME, FCI_TMP_STR,20),20, FCI_TMP_STR,20);
    FCI_SHEAD(FCI_TMP_STR,20, " M",3, FCV_TEMP_STR,20);
- it looks like FC is attempting to use FCI_TEMP_STR for multiple purposes - so for example in line 2 - it is used in FCI_TOSTRING to get the string value of FCV_ALARM_TIME - but is already in use as the temporary result string.
Posted: Sun Aug 04, 2019 10:08 am
by Jan Lichtenbelt
Hi Martin
The second line declares the error result I get, which shows the Alarm_Time to preceed all other strings.
Kind regards
Jan
Posted: Wed Aug 07, 2019 10:56 am
We've had this one on the list for a while now. It certainly does need fixing but there may be a cost in terms of bloating the RAM usage to allow us to buffer all the intermediary steps. I'll see if we can do anything to try and bump this one up so we can fix it.
