Setting up vNET
Posted: Mon Sep 02, 2019 7:07 pm
by Docara
HI
Using FC 7.3.0.5 (are there any updates by the way?)
How do you use and setup vNET? I have seen a fantastic Youtube video using V5 (I miss that GUI Interface!!!) showing how to set it up and it's use but cannot find anything similar in v7?
Re: Setting up vNET
Posted: Tue Sep 03, 2019 10:50 am
Updates for v7.3 available here.
viewtopic.php?f=63&t=19743
V7 vNet example available here.
https://www.flowcode.co.uk/wikiv7/index. ... 7bda03dc82
Re: Setting up vNET
Posted: Tue Sep 03, 2019 11:57 am
by Docara
Thanks for the reply.
Following the example, I have two FC programs running. One running Node 1 example and the other with Node 2 running, but Node 2 does not show anything when the keypad is pressed. I get nothing displayed when I click on the 'Console' via the 'VIEW' menu in the menu bar.
Where do I go from here?
Re: Setting up vNET
Posted: Tue Sep 03, 2019 1:25 pm
Have you applied the latest updates, I beleive there was a vNet fix as part of the updates.
Re: Setting up vNET
Posted: Tue Sep 03, 2019 1:31 pm
by Docara
HI Ben
As per a recent question Ifollowed your link and have upgraded to 7.3.0.7
Re: Setting up vNET
Posted: Tue Sep 03, 2019 1:47 pm
by Docara
Don't worry Ben I have just seen that you now need a licence pack for vNet. Even so I presume I should get a console of some up -shouldn't I?
