Page 1 of 2
BL0032 windspeed
Posted: Wed Sep 25, 2019 11:19 am
by Monie Jacobsen
Hi everyone
Want to be able to read pulses on one entrance.
Is there anyone here who will help
Have tried many times but without result
Med still can't read a frequency
Do you have a code suggestion so that it becomes possible to read a sequence?
Re: BL0032 windspeed
Posted: Wed Sep 25, 2019 1:57 pm
by mnf
Hi Monie,
You don't seem to enable your timer interrupt in the code sample...
Posted: Wed Sep 25, 2019 2:38 pm
by Monie Jacobsen
Hi mnf
OK, I look at this and return to you.
Thank you so much for your attention.
Posted: Wed Sep 25, 2019 3:51 pm
by Monie Jacobsen
Hi mnf
Have tried the attachment below
But can't make WindSpeed work
Attachment file:
Posted: Wed Sep 25, 2019 5:30 pm
by mnf
I did a simple frequency counter example here:
viewtopic.php?f=26&t=20970&hilit=Frequency+counter that used two interrupts to count frequency... I used a rtc chip to generate the 1s interrupt rather than an inbuilt timer.
I have an anemometer here that came from a broken weather station I will can havea play with - but not too to tomorrow evening - and hopefully you'll be up and running by then
Posted: Thu Sep 26, 2019 8:37 am
by Monie Jacobsen
Hi mnf
Thank you so much for your suggestion.
The codes look exciting.
I usedsPIC Programmer BL0032
User I2C 4 line Display:
And user input B0
User FG085 Function Generator.
When pulse in at 92 Hz is displayed "PulsIn: 5050".
Where I wanted to be shown 9.2 m/s
Do you see where things go wrong in the codes
Please see attachment:
Posted: Thu Sep 26, 2019 7:14 pm
by mnf
Hi Monie,
This is trying to do something different? Measure the length of a received pulse?
Martin1 (medelec) posted some PIC code here
viewtopic.php?f=26&t=14749&p=59273&#p59273 that may do what you need?
Posted: Fri Sep 27, 2019 10:51 am
by Monie Jacobsen
Hi everyone
Regarding interrupt port for BLl0032
Does anyone have a record of interrupt for Port and Pin. number.
Posted: Sun Sep 29, 2019 5:08 pm
by Monie Jacobsen
Hi everyone
I wish here to be able to press 2x keyboards simultaneously.
Keyboards type:BL0138
As an example: Press = 10 and Press = 11
Do you have a suggestion on how to write it as codes?
- Press.JPG (38.02 KiB) Viewed 30448 times
Posted: Mon Sep 30, 2019 8:08 am
Hi Moni,
Monie Jacobsen wrote:HI medelec35
Pulse & frequency Meter User BL0032 - 16-Bit dsPIC
I have tried a lot to make your codes work with BL0032 - 16-Bit dsPIC but,
with no luck!
Is it something you want to help with?
Please see attachment below;-)
Pulse & frequency Meter using CCP R1_v6_Test.fcfx
What about the basic frequency counter I created for you in 2012:
https://www.flowcode.co.uk/mmforums/viewtopic.php?f=28&t=20253&p=89433&#p89433
That could be a starting point for you?
Posted: Mon Sep 30, 2019 8:35 am
by Monie Jacobsen
HI medelec35
"The basic frequency counter you created for me in 2012"
It will be very good to use in connecting a
BL0032 - 16-bit dsPIC.
Just made the frequency counter work
But I do not have the opportunity to choose other ports from which I can read the Frequency.
Can only read from PB1!
Missing record for attach interrupt options, stating
Time 1 to Time 9 And their respective Pin number.
Is it something you want to help inform?
Posted: Mon Sep 30, 2019 10:01 am
Hi Monie,
you can only use different pins if the interrupt allows you to via port mapping.
Posted: Mon Sep 30, 2019 10:46 am
by Monie Jacobsen
Hi medelec35
Want to use different Interrupt for BL0032 - 16-bit dsPIC.
But the Pin numbers are missing
Therefore, I need an overview of connectivity options
- Properties Interrupt.JPG (37.38 KiB) Viewed 30419 times
Is that something you can help with?
Have no experience with IOC PORT!
See attachment:
Posted: Mon Sep 30, 2019 11:07 am
The timer interrupt is just for that purpose alone.
Does the INT/0 have a remap option?
Just select properties and change the selection to the required pin.
If not, then you can select INT/0 to INT/4.
If that is possible then hardware redesign?
Posted: Mon Sep 30, 2019 11:12 am
I have just looked at your flowchart.
You are using INT2 and it does have a remap option, so you can select RB0 to RB15 etc.
Posted: Mon Sep 30, 2019 6:02 pm
by Monie Jacobsen
Hi medelec35
Now read READ FREQUENCY_BL003 signal via Port as described below.
User:
INT4 = RB8 (Port BH)
INT4 = RB7 (Port D7G)
INT4 = RF0 (Port F0)
Thank you so much for your great help
Now I can work on the project...
Posted: Tue Oct 01, 2019 7:01 am
by Monie Jacobsen
Hi everyone
See the picture below:
- KeyPad_BL0138.JPG (31.06 KiB) Viewed 30375 times
Posted: Tue Oct 01, 2019 10:00 am
by LeighM
Hi Monie,
The design of the keypad is such that you cannot press two keys at once and know what they are.
Only one key press at a time is detected.
Posted: Tue Oct 01, 2019 10:23 am
by Monie Jacobsen
Hi LeighM
Do you have another suggestion that will have the same effect of activating 2 KeyPad?
Posted: Tue Oct 01, 2019 11:19 am
Hi Monie,
I have no idea if attached will work.
Can you let me know please?
Posted: Tue Oct 01, 2019 12:14 pm
by Monie Jacobsen
Hi medelec35
Has insert a comment in attached codes
Cannot then use KeyPad again!
Or continue with the codes afterwards!
Please see the codes here:
Attachment file:
Posted: Tue Oct 01, 2019 12:22 pm
Not sure what you are saying, but I have modified your flowchart.
Posted: Tue Oct 01, 2019 12:43 pm
by Monie Jacobsen
Hi medelec35
It just works now
Thank you very much
Looking at the first loop,it has now been made redundant.
All you need is:
Posted: Tue Oct 01, 2019 12:48 pm
Monie Jacobsen wrote:It just works now
Thanks for letting me know, I was not sure without hardware to test it on.
The flowchart is just relying on the fact that two keys are never pressed and released within a few microseconds of each other.
