Timer component
kennethnilsen69
Been thanked: 14 times
Timer component
Post by kennethnilsen69 »
Hi I have problems if I want to use more than 4 Timer components. I can not make the 5 Timer to work. In the Timer component, up to 9 Timers are available
Are there any restrictions or is this a bug?
I use:
FC7 and a EPIO40P16
TimerTest.fcfx
(67.26 KiB) Downloaded 310 times
kennethnilsen69
Re: Timer component
for the Arduino Nano I can't use any Timer components.
just by adding a Timer component on a blank project to Nano I get this error message:
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat atmega328p "C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.elf" "C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c" "C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.lst"
Launching compiler...
C:\Users\Kenneth\DOCUME~1\Arduino>"C:\PROGRA~2\FLOWCO~2\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.elf" "C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c" -lm -Wl,-gc-sections
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c: In function 'FCD_026e1_Timer1__StartCounter':
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c:284: error: expected expression before '=' token
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c: In function 'FCD_026e1_Timer1__StopCounter':
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c:397: error: expected expression before ';' token
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c: In function 'FCD_026e1_Timer1__GetRawCount':
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c:475: error: expected expression before ';' token
C:\Users\Kenneth\DOCUME~1\Arduino\TimerTestNano.c:516: warning: left shift count >= width of type
C:\Program Files (x86)\Flowcode 7\compilers\avr\batchfiles\avra.bat reported error code 1
TimerTestNano.fcfx
(11.76 KiB) Downloaded 271 times
Re: Timer component
To make sure you are using the latest files please can you make sure you are running version 7.3 and also have applied the latest bug fixes available here. viewtopic.php?f=63&t=19743
Hopefully this will solve the problem but let us know if not.
kennethnilsen69
Re: Timer component
the latest update fixed the problem with Nano but not on the EPIO40P16
