Model 3D STEP to Mesh
Posted: Thu Feb 06, 2020 5:39 am
by sundgau
on a pc, the conversion of STEP file to mesh works well but the converter does not launch on the second PC and the result is an image without link
(8.13 KiB) Downloaded 1065 times
I tried to inhibit the anti-virus, reinstall flowcode but nothing helps!
An idea?
thank you in advance
Bruno
PS: On both PCs:
Windows 10 (1909) and flowcode version 7.3.0.7
Re: Model 3D STEP to Mesh
Posted: Thu Feb 06, 2020 11:06 am
Hi Bruno,
I believe the converter opens a pop up window. Is the pop up window maybe being hidden behind something or off screen?
Posted: Fri Mar 13, 2020 1:30 pm
by sundgau
I still haven't solved this problem. Do you have a suggestion for me? The following popup window does not open and flowcode does not convert 3d files to a "mesh" file, so no link is created in "mesh".
I can, however, upload a mesh file created with another PC!
(14.77 KiB) Downloaded 915 times
I don't have or no longer have this window. I tested all the solutions: uninstall, clean up registry, installation in administrator mode, execution in administrator mode ... All the other functionalities of fc work well
(4.57 KiB) Downloaded 915 times
An idea?
Bruno
Posted: Fri Mar 13, 2020 2:55 pm
by stefan.erni
Hi Bruno
Check your path from the filename. Sometimes letter like "äöüé" from swiss-german give this problems.
or
There is a trial software for 90 day's you can use for convert, test, remesh, from all format to all format....
https://www.rhino3d.com/de/download
