Internal DAC error FC8
Posted: Thu Feb 06, 2020 2:56 pm
by pollob
sir,
Internal DAC of atxmega32a4 doesn't work.it's giving error while compiling.
Re: Internal DAC error FC8
Posted: Thu Feb 06, 2020 9:24 pm
by kersing
Can you post (attach as file) a flowchart that shows the problem?
Posted: Fri Feb 07, 2020 11:53 am
There is nothign available in the channel drop down so either the device does not have an internal DAC or we don't currently support it.
Looking at the datasheet I see it does have a DAC so I'll see how easy a job it is to add support for it.
Posted: Fri Feb 07, 2020 2:49 pm
I've now added support for the two DAC channels onboard the ATXMEGA16A4 and ATXMEGA32A4 devices, if you do a full update (Help -> Check for updates) then you should get all the files required.
For help see here.
https://www.flowcode.co.uk/wiki/index.ph ... _all_files
Let me know how you get on.
Posted: Fri Feb 07, 2020 5:17 pm
by pollob
this is the output from com compiler
Target folder: C:\Users\pollob\Desktop\NEWFOL~2
Source name: C:\Users\pollob\Desktop\New folder (2)\Flowcode1.fcfx
Title:
Description:
Device: AVR.ATXMEGA.ATXMEGA32A4
Generated by: Flowcode v8.2.1.13
Date: Friday, February 07, 2020 22:16:31
Users: 1
Registered to:
License key: *****
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\avr\batchfiles\avra.bat atxmega32a4 "C:\Users\pollob\Desktop\NEWFOL~2\Flowcode1.elf" "C:\Users\pollob\Desktop\NEWFOL~2\Flowcode1.c" "C:\Users\pollob\Desktop\NEWFOL~2\Flowcode1.lst"
C:\Users\pollob\Desktop\NEWFOL~2>"C:\PROGRA~2\Flowcode\Common\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atxmega32a4 -Os -ffunction-sections -fdata-sections -funsigned-char -o "C:\Users\pollob\Desktop\NEWFOL~2\Flowcode1.elf" "C:\Users\pollob\Desktop\NEWFOL~2\Flowcode1.c" -lm -Wl,-gc-sections
C:\Users\pollob\AppData\Local\Temp/cc53vcpk.o: In function `main':
Flowcode1.c:(.text.main+0x0): undefined reference to `FC_CAL_DAC_Enable_1'
Flowcode1.c:(.text.main+0x8): undefined reference to `FC_CAL_DAC_SetOutput_1'
Error returned from [avr-gcc.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\avr\batchfiles\avra.bat reported error code 1
Autoclose turned off
FINISHED
Posted: Fri Feb 07, 2020 5:33 pm
by pollob
now its work fine.thanks :D
