Toolbar problem and Pic18F24K22 compiler error
Posted: Sun May 17, 2020 10:11 pm
by Bruno
Hi Benj
I recently purchased the license of flowcode8 and I encountered two problems: the toolbar cannot be moved as in flowcode7 or flowcode6, as shown in the attached photo.
(24.73 KiB) Downloaded 130 times
The second problem is with a Pic18F24K22, the compiler gives the following error:
Title:
Description:
Device: PIC.18F.18F24K22
Generated by: Flowcode v8.2.2.15
Date: Saturday, May 16, 2020 23:59:31
Users: 1
Registrato a:b.sgammato
Chiave di licenza:XXXXX
https://www.flowcode.co.uk
Avvio del compilatore...
C:\Program Files (x86)\Flowcode v8\pic\batch\pic_xc8_comp.bat 18F24K22 "C:\Users\BRUNO_~1\Desktop\TEST_P~1\" "Test_Array_Bit"
C:\Users\BRUNO_~1\Desktop\TEST_P~1>C:\PROGRA~2\FLOWCO~3\pic\batch\..\bin\xc8.exe --chip=18F24K22 "Test_Array_Bit.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
C:\PROGRA~2\FLOWCO~3\pic\include\pic18f24k22.h:
8244: extern volatile unsigned char TRISE @ 0xF96;
(985) qualifiers redeclared ^
^ (1098) conflicting declarations for variable "TRISE" (Test_Array_Bit.c:29)
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode v8\pic\batch\pic_xc8_comp.bat ha riportato il codice di errore 1
best regards
Re: Toolbar problem and Pic18F24K22 compiler error
Posted: Mon May 18, 2020 12:38 am
Hi Bruno
While waiting for the bug to be fixed, there is a workaround.
Select Help, Check for Updates,
Select Show Up to-date files
Select the 18F24K22.fcdx so its ticked.
Change the New Revision number from 3 to 2 then select Download
Finally Select Exit then Reload (third from the left at top,next to Save)
As for the toolbar.
Select View, Global options
Within Flowchart tab, untick Bind an icon toolbar to each programming view
Posted: Mon May 18, 2020 8:53 am
by Bruno
Hi medelec35
I followed your instructions and solved the problems
thanks for your help
best regards
Posted: Mon May 18, 2020 10:36 am
Should be fixed now, thanks :D
Posted: Mon May 18, 2020 11:49 am
by Bruno
Hi Beny
Yes with revision 4 it works, thanks :D :D
Posted: Mon May 18, 2020 11:56 am
by Bruno
Sorry ..... Benj :) :)
