I need to use this module in a project.
It already comes with a ds 1307 watch and a sd card. The watch I am using the ds1307 component of the flowcode. And how do I write data to the card if the communication with it is I2C?
I am attaching a link so you can understand how it works.
https://www.youtube.com/watch?v=nCQZWdL3BGE
Thankful;
Ricardo.
help with data logging shield v 1.0
- Has thanked: 182 times
- Been thanked: 179 times
Re: help with data logging shield v 1.0
Hi Ricardo
For the SD card you can use the pins for SPI. This pins are on the right side on a "strange" connector
To start program the SD Card just drag and trop from the component Data the component FAT(SD, SDHC) on your dashboard and try it!
- Bachman
- Has thanked: 9 times
- Been thanked: 53 times
Try to search for "openlog module", the easiest way to make data logger. You need only UART (RS232) communication, everything else is made by the module.
