SSD1963 hardware not working properly
- Has thanked: 8 times
- Been thanked: 8 times
Hello!
So I am trying to implement a nice LCD screen with touch(ssd1963) and I ordered one but until it arrives I decided to prepare the software .Unfortunately, when I try to load a bitmap from bitmap drawer fat it doesn't display anything. For the photo, I try to use the dragon for the glcd flowcode example and it works with other screens ex. ILI9341 (simulation and real).
Any pointers please? maybe i am missing something!!
- GLCD7_Touch.fcfx
- (16.97 KiB) Downloaded 406 times
Re: SSD1963 simulation not working properly
I've replicated the problem, started looking for you yesterday but then got pulled onto something else. I'll look again for you today.
Hello again,
Any news? I need it for a product release??
I'll try and have a look for you tomorrow, sorry for the delay. Does the code work ok on hardware or is it not working there either?
I have had a look for you a few times now and get so far into it and then get something else come in that needs attention. I'm out the office tomorrow so hopefully a good oppertunity to have a good look for you.
Should be fixed for you now via the update system.
Let me know if you have any problems.
Thank you so much benj,
I ll check it this week both hardware and software and let you know...I havent tried on hardware yet because screen arrived today!!!good timining
I ll keep you posted!!!
Thanks again for your support and quick response!!!!
New product due to be released until December
You are a life savior!!!
Hello again...so I tested the hardware and unfortunately no go...
the screen is this one https://www.ebay.com/itm/7-inch-800x480 ... 2749.l2649
and I have my project attached...pretty simple really pic18f67j50 with 18432000 external crystal. Flashing led and try to print hello.
Led is flashing but tft turns black when I power on and stays black.
Connections are 3x checked
TFT - pic
data port - D0-D7
CS - C0
WR - C1
RD - C2
RS - C3
REST - C4
5V - 5V (BACKLIGHT)
3V3 - 3V3 from a regulated power supply
grd - grd
Any help would be much appreciated
TFT - pic
data port - D0-D7
CS - C0
WR - C1
RD - C2
RS - C3
REST - C4
5V - 5V (BACKLIGHT)
grd - grd
- multiplexer.fcfx
- (12.78 KiB) Downloaded 325 times
Re: SSD1963 hardware not working properly
Hello again!!!anyone has experience in above screen!!it is supposed to be tested and working.
- Has thanked: 1135 times
- Been thanked: 299 times
Hi karoubas!
Don´t know if it is the same as in the other display. But you need to give the display some more info (setting) I change a little in your program, maybe it can give you some help. now it work in simulation but slow, maybe a "heavy display" need a fast processor. But look good, and expensive
Could be.
Jorgen
Could be.
Jorgen
- multiplexer1.fcfx
- (13.43 KiB) Downloaded 372 times
Dear jgu1,
Thank you very much for your response and effort but unfortunately, after loading your code the result is still the same....black screen...
Thank you Martin!!
Just tried and nope...no difference in hardware same result...black screen...
But i wonder .....i have a dspic33fj256gp710a and i will try it tomorrow
- Has thanked: 70 times
- Been thanked: 440 times
Hopefully some luck..
Sorry, but don't have one of the displays to try - so can only suggest the usual 1s blinkie, wiring and the like.I
The fact that you even try is much appreciated!!!
Thank you!!
Thank you!!
dspic33fj256gp710a with INTERNAL FRC W/PLL 48Mhz also no working.....led blinks.....I have ordered a pic32 80Mhz but with the covid situation, it will take forever to arrive.....bummer...
Any suggestions will be appreciated...
Give us a pointer to the exact type of display you are using - there are lots using the same controller....
I don't think the MCU is the problem - speed / memory should be sufficient so that leads to:
1) Hardware error. Something in the setup doesn't work. So display is faulty / wiring is faulty / MCU is faulty.
(Note we can probably rule out 1 and 3...)
or
2) Software error - something in the timing or setup doesn't work / the component doesn't work / the MCU isn't communicating properly (WDT issues seem common)
I would try and get the display working first (forget touch and SD) then build on that..
Note - I've been 'playing' with some ST7789 displays and managed to get some displays running and others not - and I suspect a 'subtle' difference in startup requirements between chip revisions - but stumped at the moment
or
Dear Martin on previous posts i have informed on all the informations i have including links to the screen as well as a test flowcode...i am just trying to make the screen go only for now...
The connections cannot be the problem 3 days i am checking and checking....
But thanks again for your guidance!!!
Anyone from flowcode team care to give some support?
Thank you!!!!
Thank you!!!!
I tried with internal OSC w/pll at 40Mhz on the dspic33fj256gp710a and reached 500000 baudrate
nice find but the screen still doesn't work...sometimes when I change configurations I can see flashing constantly other times I can see white noise with a few colour lines....bummer....I am in a dead-end I do not where to look
Well after more searching i came to the conclusion that maybe flowcode init uses the pmp of the pic32....so since there is nothing else to try with the pics i have, i ll wait until the pic32mx764f128h arrives and i try again covid 19 delays
Anyway thanks for the support...
I had a dig for my 1963 display but couldn't lay my hands on it. I'll keep looking to see if I can help.
PIC32 shouldnt be required.
Thanks Benj,
I hope you can have the time because i was pretty sure that this component works before i order and plan my new release (i shouldn't before i actually tested) and now nothing....
I will look forward to your reply and just keep trying...
